Online Now [332]:
Visitors: 331
Today: 116566
Total: 157305656
Forums › The Car › 206 Talk › new axle fitted ( bad knocking )
Forum Index › 206 Talk
Project2062014
PostPosted: Fri Jan 23, 2015 9:54 am Up
Hi . So ive fitted a new axle, shocks,wheel bearings .also lowered 50mm done by imaxle .
Ive double checked all bolts nut are nice and tight dropped the car .Rear brake line was rubbing on inside bk left .
moved out of way tie wrapped up .
Full clearance on each wheel nothing moves no play in axle or wheel bearings .
Off down the road to a knocking its got worse over a mile .
pulled up check it out nothing seems strange .
returned home jacked it up & all tight no play .
Where could this knocking be comin from ? .
PostPosted: Fri Jan 23, 2015 10:52 am Up
Exhaust?
PostPosted: Fri Jan 23, 2015 11:18 am Up
Exhaust can hit the lower torsion bar. Rear anti roll bar not in properly?
Project2062014
PostPosted: Fri Jan 23, 2015 11:27 am Up
Nope.. not exhaust . To dark to see il check more in morning .
ukskater01
PostPosted: Fri Jan 23, 2015 2:37 pm Up
Spare wheel carrier or exhaust, after my axle was replaced the exhaust knocked over bumps but wouldn't hit the body when moved by hand.
PostPosted: Fri Jan 23, 2015 4:06 pm Up
Bump stops, exhaust, spare wheel and anti roll bar would be my ideas
Ive got one atm which im yet to strip, which makes a click and a knock when you hit the inside of either wheel from inside the tube....
Project2062014
PostPosted: Fri Jan 23, 2015 6:21 pm Up
defo the back box catching the rear shock just that last 50mm drop off the jack and it squeezes the back box right .
Its perfect in the exhaust cut out . Box is too wide or cars too low (not)
PostPosted: Sat Jan 24, 2015 3:52 am Up
That new axle wont last long by the looks of it either.
PostPosted: Sat Jan 24, 2015 4:21 am Up
Why on earth is it that low?
Project2062014
PostPosted: Sat Jan 24, 2015 12:13 pm Up
50mm drop imaxle .. was told passed 60mm is not under warranty and not advised . 50mm was ok .
Does seem low . Prosport rear shocks make any difference ?
PostPosted: Sat Jan 24, 2015 2:06 pm Up
No need to be that low. Bearings wont last long. Needs to raised about 20mm. Are you using the standard shocks
PostPosted: Sat Jan 24, 2015 3:15 pm Up
That will be sat on the bump stops.
Project2062014
PostPosted: Sat Jan 24, 2015 6:26 pm Up
Prosport rear shocks .
In both pics its tight on the handbrake so its sittin a little lower than it would on flat ground .
It sits perfectly level hoping the front will drop a few mm
Project2062014
PostPosted: Sat Jan 31, 2015 4:37 am Up
It was that low the sway bars was hitting the rear shocks .
checked axle & imaxle has dropped it 80mm and put the 19 mm torsion bars in the axle .(wrong ones as its a 180 21mm)
It tried to cut my exhaust in half .
Ive returned the axle's(old one exchange aswell) to imaxle to sort it out .
i fitted £100 wheel bearings with hubs .
unable to remove them because of the risk of damage .
Im 375 out of pocket with no axle for my car until i get the recon returned .
Not happy as silver gti has no mot from monday (also need a axle)
Il have no car = no work = no money . Not happy one bit .
