Forums › The Car › Solved 206 Problems › 04 206cc turns over wont start |
Posted: Sat Jan 24, 2015 5:27 am |
Hi I have got a 206cc 1.6 it will turn over but won't start any ideas please thank you regards chris
Posted: Sat Jan 24, 2015 7:35 am |
Can you see the camshaft if you take the oil filler cap off? Does the cam turn when the key is turned?
Posted: Sat Jan 24, 2015 7:57 am |
Crank sensor
Posted: Sat Jan 24, 2015 8:00 am |
Sorry should say more. Check you ingredients chef lol
Fuel/pump
Air flow
Spark/crank sensor
Scan codes
Hope you find a solution
