Latest: Andyblue64
Overall: 17123
Online Now [296]:
Visitors: 295
Today: 73398
Total: 98442113
Forums › The Car › 206 Talk › Quick gearbox question
Lumpymash
PostPosted: Wed Jan 28, 2015 4:28 pm Up
Hi guys,
Just wondering if the 2.0 206 cc gearbox would fit a 2.0 206 gti.
I'm after a new gearbox and found a cc breaking close to me.
Thanks for your help.
PostPosted: Wed Jan 28, 2015 4:38 pm Up
Yes it's the same gearbox.
Lumpymash
PostPosted: Wed Jan 28, 2015 5:07 pm Up
Thanks for the reply.
So it would have the linkages, not a cable like the gti 180.
Hope that makes sense I've only had my car a week and only really know what I've read today.
(I have the 140)
Lumpymash
PostPosted: Thu Jan 29, 2015 5:00 pm Up
I keep reading about hydraulic clutches etc.
Will everything be the same on a cc as my gti 138?
I've been offered the box and sorted a price, just want to double check before I buy.
Thanks, Jon.
Lumpymash
PostPosted: Thu Jan 29, 2015 5:11 pm Up
The cc is a 51 plate.
My gti is a 52 plate. Registered in jan 2003
PostPosted: Thu Jan 29, 2015 9:11 pm Up
Yes, everything is the same between the GTi and the CC. Both run BE4 gearbox's, both have gear linkage rods not cables, both run hydraulic clutch set ups.
Lumpymash
PostPosted: Fri Jan 30, 2015 2:27 am Up
Thanks for the help!
I'm a bit confused now, as it asked the same question on a 206cc forum and someone said in 2002 they swapped between using a cable and hydraulic. If that makes sense?
PostPosted: Fri Jan 30, 2015 3:27 am Up
All right hand drive Used hydraulic clutches regardless of year.
