Online Now [721]:
Visitors: 720
Today: 118993
Total: 157424548
Forums › Tuning, Modification & Legal › Project Cars › ZiAn's pride & joy 206GTi (EW12J4 in progress) pg.9
Go to page Previous  1, 2, 3 ... 10, 11, 12, 13  Next
heyziq
PostPosted: Mon Apr 08, 2013 4:38 am Up
=ZiAn= wrote:
@heyziq, yes it's been quite a while now, but that's due to some other things taking priority before the project. So now I'm taking it one step at a time, but do hope to have it finished till the end of summer... hopefully Smile
i believe u will need piggy back or stand alone, as you will using the original 206 engine wiring right?
heyziq.com
=ZiAn=
PostPosted: Mon Apr 08, 2013 5:03 am Up
yup I'll be using a DTA s60pro (standalone ECU)...that's actually one of the final parts missing (the cams are being ordered as I'm writing this) Smile
ZianDesigns - Website designs
Goldin
PostPosted: Tue Apr 09, 2013 8:15 am Up
=ZiAn= wrote:
So in the past week we've changed the torsion bars for the 21mm Peugeot Sport bars and the ride difference is unbelivable. This is one of the most under-done mods around and it's so worth it. The car feels more balanced and doesn't squeek over potholes and bumps, not to mention the cornering characteristics have improved significantly. The turn in feels alot more neutral almost a bit tail happy, where before it was quite understeerish.
Same here, I also changed 19,5mm for 21mm torsion bars, and I agree with every single word.
We have similar suspension setup on cars, and I am now thinking about 206 RC front ARB.
=ZiAn=
PostPosted: Tue Apr 09, 2013 11:28 am Up
Why would you want a thicker front ARB? It would only add to the (still existing albeit not too noticable) understeer. I'd rather take a look at an aditional rear ARB. It would make sense though, if you used the 23mm torsion bars as it would (probably) be a bit too tail happy Smile
PostPosted: Tue Apr 09, 2013 11:58 am Up
I'd wonder what 23mm torsion bars would do to the bodyshell long term. They are after all intended for tarmac rally use on cars with full cages fitted!
Goldin
PostPosted: Tue Apr 09, 2013 2:07 pm Up
ZiAn, what do you mean about aditional ARB?
I changed ARB, and fitted GTI180 22mm ARB.
=ZiAn=
PostPosted: Sat Apr 27, 2013 7:39 am Up
@Goldin, I was referring to the aftermarket Whiteline rear ARB Wink Check it out, it just might be worth it for you, as you also uprated the front Wink
=ZiAn=
PostPosted: Sat Apr 27, 2013 7:45 am Up
Another update Smile I had some spare time and finally did the mod I wanted to do for a very long time Smile
I think it turned out quite okay:
also I think the current engine is still quite healthy...it had no problems with a midnight run Very Happy
=ZiAn=
PostPosted: Thu Jan 29, 2015 3:15 pm Up
Quick update after a long while Smile
New wheels --> OEM ones of a GTi180
New brakes --> changed the 607 Brembos for 406 Brembos (should get them mounted in the spring)
New ECU for the 2.2 project --> ECUMaster EMU
And the 2.2 16v engine is finally getting put together, so in about 3 months it should be up and running Smile
Pics will follow, when I'll have some spare time Smile
usher
PostPosted: Fri Jan 30, 2015 7:13 am Up
glad this is stil going, when you planning the engine swap
current bam project insta
project thread WIP
garage
FAQ
206 gti firedance
samversteeg
PostPosted: Fri Jan 30, 2015 12:16 pm Up
Love the project! I've seriously considered this swap.
Goodluck
206gt160
PostPosted: Thu Mar 12, 2015 8:14 am Up
=ZiAn= wrote:
haha tb206hdi, yes that's quite annoying Very Happy but I got used to it. At first my friends were laughing their asses of as they thought I was switching on the indicators while steering left and right Laughing
And back to the topic, we've decided that we're going to make our own throttle bodies. The reason for this, they can be designed just the way we want to, they will be far cheaper than Jenvey ones and we can make them look as standard as possible.
BTW I found a pic of the car on the latest track setup Twisted Evil
I believe I'll keep the all white theme on racetracks Twisted Evil
May have missed it but what size are the steel wheels and do you know the weight of them?
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
=ZiAn=
PostPosted: Thu Mar 12, 2015 4:29 pm Up
@Usher, when the mechanics get it all together Smile Should be in about a month or two as they a re a bit busy... But if I've waited for the last 4 years I can wait a few months more Smile
@206gt160, 15" Citroen c5 if I'm not mistaken and they were super light (don't quote me but i believe they were around 6kg?).I'll ask the owner of the wheels when I get to see him Wink
tRiCk
PostPosted: Thu Mar 12, 2015 8:39 pm Up
What are you planning to do with the balancer shafts in your engine? I've got an ew12 in my car happy to help with any info and spare parts
RandomGT
PostPosted: Fri Mar 13, 2015 3:16 am Up
Loving this project Very Happy And it keeps me motivated even more..If you get your engine sorted out in time,and coming to Croatia this summer,let me know Wink
Page 11 of 13
