Online Now [374]:
Visitors: 373
Today: 87359
Total: 156965413
Forums › The Car › 206 Problems › prolems on first start up
dj71
PostPosted: Tue Feb 03, 2015 5:53 am Up
hi, my 2008 206 has started to give me problems which is driving me mad.
after the car has stood over night i start it up to go to work (it starts first time with no problems) i pull away and it runs bad as if its got a missfire, as soon as i change to 2nd gear it cuts out and i struggle to get it started again, after about 5 goes it finally gets going although running poor, i did notice if i leave the car running for 10 mins or so at the start to defrost the windscreen the car doesnt cut out when i dive off but still runs poor, thinking it was plugs or ignition coil these have been changed along with air filter and map sensor, now im at a loss as to what it can be, any help would be very welcome
dj71
PostPosted: Tue Feb 03, 2015 12:01 pm Up
Have you checked for codes?
dj71
PostPosted: Tue Feb 03, 2015 12:43 pm Up
hi Addaz, i bought a reader today, and its showing no codes which is why im now stummed as to what the problem is,
i am having problems with my positive battery terminal corroding with a white substance, not sure if that could be related as it does start first time and its never flat on a morning, the car just bogs down when i first set off and cuts out unless i warm the engine first
dj71
dj71
PostPosted: Thu Mar 05, 2015 6:07 am Up
any ideas?
dj71
Razor34
PostPosted: Thu Mar 05, 2015 1:26 pm Up
How old is the battery? If old replace and do a BSI reboot (guide on here through search) and may solve your problems
Ray
PostPosted: Thu Mar 05, 2015 2:00 pm Up
Check your battery, recheck the plugs, replace the temp sensor (as ive had these play up)
What engine is it btw? 1.4 16v by any chance?
johnpidge
PostPosted: Fri Mar 06, 2015 10:58 am Up
no codes - hmmm odd - could be plugs or coil pack or temp sensor but should come up with some code
Disconnect the battery for 30 minutes to reset everything - i did to clear a few things - codes still there but at least the engine light has gone out
John
dj71
PostPosted: Tue Mar 17, 2015 10:31 am Up
someone suggested changing the lambda sensor which i did today, now its worse than ever with constant rough running and also i now have the engine warning light on, iv checked the code and its p0036 iv googled it and it says to check the oxygen sensor fuse first but i cant find where the fuse is, any help would be great, the car is a 2008 peugeot 206 look 1.4 petrol
dj71
Carlos_WR1
PostPosted: Tue Mar 17, 2015 11:06 am Up
I assume you disconnected the battery when you fitted the new Lambda Sensor?
johnpidge
PostPosted: Tue Mar 17, 2015 11:20 am Up
would give you that fault code????????
John
dj71
PostPosted: Tue Mar 17, 2015 11:57 am Up
nope i forgot too, would disconecting it now for half an hour reset it?
dj71
PostPosted: Tue Mar 17, 2015 12:42 pm Up
Was your replacement lambda a cheap one by any chance?
dj71
PostPosted: Tue Mar 17, 2015 12:51 pm Up
from a car part store, £70
dj71
Carlos_WR1
PostPosted: Tue Mar 17, 2015 3:56 pm Up
I was wondering if the battery wasnt disconnected when the new Lambda sensor was fitted whether this could have blown a fuse hense the fault code?
I could be wrong and clutching at straws but regardless i wouldnt have thought it good practice to unplug and plug in a new sensor with the battery still connected on both terminals
johnpidge
PostPosted: Tue Mar 17, 2015 4:02 pm Up
I wasnt sure if that would blow a fuse??
John
