Latest: Andyblue64
Overall: 17123
Online Now [156]:
Visitors: 155
Today: 63704
Total: 99288430
Forums › The Car › 206 Problems › Engine Misfire
Engine Misfire
pugalug
PostPosted: Sun Feb 08, 2015 4:07 pm Up
Hi All,
Wondering if anyone can help me with an engine misfire i've been having on my 206 for a few months. 1.4 petrol 2002 with 70k on it.
It only misfires when idling
Sometimes stopping and starting the engine cures it
I've tried several coil packs and that's not solved it
There's no engine codes on when I scan it
Any advice very appreciated!
cheers!
PostPosted: Sun Feb 08, 2015 4:18 pm Up
have you replaced the spark plugs?if you did hope that you have not used NGK ones ,if so,it will cause u lots of problems.
pugalug
PostPosted: Sun Feb 08, 2015 4:37 pm Up
I have tried new plugs, Bosch i think they were. Would they come up on a scan as being a problem do you think?
PostPosted: Sun Feb 08, 2015 4:44 pm Up
well a misfire can be read on PP2000,if it's on multiple cylinders,then it's the coil pack,but it's on a certain cylinder,then you have a problem with the spark plug on the cylinder,or maybe a mechanical issue.
