Latest: Mr-Koekwaus
Overall: 17125
Online Now [67]:
Visitors: 66
Today: 24660
Total: 99384341
Forums › The Car › 206 Talk › oil catch tank
oil catch tank
Bigbenj_08
PostPosted: Mon Feb 09, 2015 7:21 am Up
Hi all,
Anyone fitted an oil catch tank to their 206?
I've been reading up and the consensus seems to be that as always you get what you pay for.
just wonderin whos got what and does it work?
I've noticed I get a dribble of oil out of th breather pipe, so was planning on putting a catch tank in rather than it dribbling back into the intake.
Ben
Aegean Blue 1.6 16v Sport
PostPosted: Mon Feb 09, 2015 1:35 pm Up
Is that true about getting what you pay for? It's a glorified jam jar at the end of the day.
Bigbenj_08
PostPosted: Mon Feb 09, 2015 3:13 pm Up
Tbh, thats what I thought until I googled it!
I'm set to buy a cheapo eBay one, but reading up that alu cans can cause a lot of condensation to be created in the intake.
gazza82
PostPosted: Tue Feb 10, 2015 5:44 am Up
I think that is how it is intended to work .. it burns off by being pushed back into the engine rather than forming a puddle on the ground somewhere ...
I know it gums up the throttle body if it is a lot, but then you have other issues .. worn valves stems/seals/etc
