Online Now [594]:
Visitors: 593
Today: 119204
Total: 156471533
Forums › The Car › 206 Problems › Wires near drivers headlight
Leegsi
PostPosted: Thu Feb 12, 2015 1:25 pm Up
Just looked at a friends car after another friend tried to replace an Aux belt.
In doing so he unplugged a load of wires for better access and now cant remember where they go.
Can anyone tell me what wires (Colour lug and wires) go where please.
PostPosted: Thu Feb 12, 2015 1:36 pm Up
what model engine he got?
Leegsi
PostPosted: Thu Feb 12, 2015 1:39 pm Up
Its a 2003 1.6 CC with the twin optic clear lights with aircon
PostPosted: Thu Feb 12, 2015 2:05 pm Up
well as far as I know,there is no much wires there,unless he unplug the engine ECU,but why he removed the wires,fitting an AUX. Belt needs nothing to be removed,but the wheel liner.
Leegsi
PostPosted: Thu Feb 12, 2015 2:19 pm Up
Will take some pictures tomorrow.
Indicator wasnt working so just checked the bulb and the holder,plug and loom isnt connected.
Looks like the wires have been caught and damged/cut/worn though (They drove it with the wires hanging) so I now have to find where those wires go as there is about a foot of wire before the cut.
PostPosted: Thu Feb 12, 2015 2:23 pm Up
pics will be very helpful so that we can help you :),so will check this thread tomorrow for pics
PostPosted: Thu Feb 12, 2015 2:38 pm Up
There are four connectors for each headlight. Which ones are cut?
Leegsi
PostPosted: Fri Feb 13, 2015 6:38 am Up
One plug was the indicator.
That leaves these 2:
PostPosted: Fri Feb 13, 2015 7:56 am Up
Why is the indicator removed instead of just disconnecting it?
Leegsi
PostPosted: Fri Feb 13, 2015 12:46 pm Up
I had removed the headlight to sort out where the wires were and just plugged the bulb holder so I knew what that plug was.
Leegsi
PostPosted: Sun Feb 15, 2015 2:02 pm Up
Any ideas on these wires (The condenser for the aircon has been removed)?
PostPosted: Sun Feb 15, 2015 2:31 pm Up
the best way to fix this problem is to take pics of my car,and post it here so u can see what is wrong Wink
Leegsi
PostPosted: Mon Feb 16, 2015 12:37 pm Up
Pretty sure that part of the loom should be behind the grill
PostPosted: Mon Feb 16, 2015 12:44 pm Up
Where's the slam panel and radiator housing? Has it had a front end bump.
Leegsi
PostPosted: Mon Feb 16, 2015 1:48 pm Up
It has and I had pulled it up out the way to see what damage there was
