Posted: Thu Feb 12, 2015 1:25 pm |
Just looked at a friends car after another friend tried to replace an Aux belt.
In doing so he unplugged a load of wires for better access and now cant remember where they go.
Can anyone tell me what wires (Colour lug and wires) go where please.
Posted: Thu Feb 12, 2015 1:36 pm |
what model engine he got?
Posted: Thu Feb 12, 2015 1:39 pm |
Its a 2003 1.6 CC with the twin optic clear lights with aircon
Posted: Thu Feb 12, 2015 2:05 pm |
well as far as I know,there is no much wires there,unless he unplug the engine ECU,but why he removed the wires,fitting an AUX. Belt needs nothing to be removed,but the wheel liner.
Posted: Thu Feb 12, 2015 2:19 pm |
Will take some pictures tomorrow.
Indicator wasnt working so just checked the bulb and the holder,plug and loom isnt connected.
Looks like the wires have been caught and damged/cut/worn though (They drove it with the wires hanging) so I now have to find where those wires go as there is about a foot of wire before the cut.
Posted: Thu Feb 12, 2015 2:23 pm |
pics will be very helpful so that we can help you :),so will check this thread tomorrow for pics
Posted: Thu Feb 12, 2015 2:38 pm |
There are four connectors for each headlight. Which ones are cut?
Posted: Fri Feb 13, 2015 6:38 am |
One plug was the indicator.
That leaves these 2:
Posted: Fri Feb 13, 2015 7:56 am |
Why is the indicator removed instead of just disconnecting it?
Posted: Fri Feb 13, 2015 12:46 pm |
I had removed the headlight to sort out where the wires were and just plugged the bulb holder so I knew what that plug was.
Posted: Sun Feb 15, 2015 2:02 pm |
Any ideas on these wires (The condenser for the aircon has been removed)?
Posted: Sun Feb 15, 2015 2:31 pm |
the best way to fix this problem is to take pics of my car,and post it here so u can see what is wrong
Posted: Mon Feb 16, 2015 12:37 pm |
Pretty sure that part of the loom should be behind the grill
Posted: Mon Feb 16, 2015 12:44 pm |
Where's the slam panel and radiator housing? Has it had a front end bump.
Posted: Mon Feb 16, 2015 1:48 pm |
It has and I had pulled it up out the way to see what damage there was
