Latest: sparrowdclxvi
Overall: 17139
Online Now [291]:
Visitors: 290
Today: 19579
Total: 112703605
Forums › The Car › 206 Talk › 206 styling
206 styling
raz24
PostPosted: Fri Feb 13, 2015 3:01 pm Up
I have a 03 plate 206 1.4hdi. Need some ideas on what to do on the aesthetics. It has the phase 2 rear lights and phase one front lights running HID's. GTI 140 interior has gone in last weekend and the GTI 180 voted wheels are in for refurb and should be fitted this weekend. Car is moonstone and Has the non-sport bumpers.
Need help/advice on the following:
Crystal lights or angel eyes?
What size spacers can I fit to make it look better/more aggressive and which make is best?
Which springs would you recommend for lowering?
How do I know if the car is multiplex?
Has anyone smoothed any of there bumpers and what does it look like.
Any other little mods would be appreciated just to help make it look that bit better.
macj
PostPosted: Fri Feb 13, 2015 3:04 pm Up
Have you tried the search function on here for starters.... many of your topics have been covered. Welcome to the forum
raz24
PostPosted: Fri Feb 13, 2015 3:06 pm Up
Ok I'll have look now and thanks for the welcoming.
RichardEke
PostPosted: Fri Feb 13, 2015 3:09 pm Up
Hi there, the difference between multiplex and preplex is iutlined in the beginners guide:
www.206info.co.uk/Foru...c/t=20541/
The 'Project cars' section is a good place to look for ideas and what different parts look like.
Hope that helps, Richard.
Life would be easier with universal jointed arms and fingers sometimes
raz24
PostPosted: Fri Feb 13, 2015 3:27 pm Up
One quick thing really would like to change to crystal lights and I'm not too handy myself anyone know where to buy and adapter and also because of the non sport bumper are there any grills that will make it look a tad better. One last thing is do any of you guys know anyone who has or manufactures a 'bad boy' bonnet
raz24
PostPosted: Fri Feb 13, 2015 5:43 pm Up
If anyone could help. I've gone from 14" nimrods to the vortex style wheels running 205/50/17 the cars currently non sport and standard and a 1.4hdi will I incurr any massive problems fitting these to the car?
PostPosted: Sat Feb 14, 2015 1:09 am Up
Because your car is a 2003 model it should have come with crystals/double optic lights as standard.
Depending on how the frosted with HIDs were fitted will depend on what you need. If the previous owner butchered the wiring then you might need to build a short loom, if they did the job properly, the connectors may still be there.
The adaptors are available from the dealer, but I would investigate under the bonnet before spending the money.
SP grills are available. No doubt a search on ebay will throw some up
Doesn't really warrant a response. You could try searching google to find who makes/sells them.
raz24
PostPosted: Sat Feb 14, 2015 3:58 am Up
Thanks for the response I will have a look at it all today. Could you advise on the tire situation I've a read a few different things now and ive already ordered brand new tyres so feel like ive thrown money away already?
Lecktorious
PostPosted: Sat Feb 14, 2015 5:32 am Up
Trade Rating: +59
What size did you order?
'98 Nile Blue 306 GTi 6
raz24
PostPosted: Sat Feb 14, 2015 11:34 am Up
Sorry for the late reply the tyres I've ordered are 205/50/17. I've read that I should be using 195/40/17? I want to lower the car too and fit spacers. Any advice would be much appreciated
PostPosted: Sat Feb 14, 2015 11:54 am Up
2003 built 206's are likely to have both H4 & H7 wiring plugs present on the loom as late 2003 was change over to phase 2 when crystal lights where standard fit.
Would still need a BSI tweak for crystal lights Wink
raz24
PostPosted: Sat Feb 14, 2015 12:10 pm Up
I had a look today and I couldn't see any other wires attached to the h4 plugs. Maybe mine was just an early version. But thanks for the response. Do you know anything on my tyre situation.
mtempsch
PostPosted: Sat Feb 14, 2015 12:47 pm Up
205/40 is the standard size on 17" for the GTi180, so 205/50 will be bigger by 6,9% (which translates to ~20 mm bigger radius, so tighter in the arches) and your speedo will show low ... If they'll catch on anything or not I don't know, never heard of anyone running that size though.
Normally recommended to keep within max 2,5-3% of stock diameter.
Silvermetallic 2004 206 RC
raz24
PostPosted: Sat Feb 14, 2015 1:00 pm Up
Right thanks for that I'll mention it to the tyre guys. Just wasted 95 on two tires that won't fit properly.
MrWhite
PostPosted: Sat Feb 14, 2015 2:34 pm Up
I struggled with 205/50 and 205/45's on mine due to fouling the filler pipe on the rear and rubbing on full lock at the front. So I have 205/40/17's on mine. Check out my project in the sign for some ideas
My 206 Project Thread
