Latest: Mr-Koekwaus
Overall: 17125
Online Now [174]:
Visitors: 173
Today: 7904
Total: 99367640
Forums › The Car › 206 Talk › 1.4 HDI sluggish
1.4 HDI sluggish
glenpring
PostPosted: Mon Feb 16, 2015 3:20 am Up
Hi all been away from the site for a long time since getting rid of my 307. The wife has a 206 1.4 HDI and I drove it yesterday night and noticed there was hardly any power, now I know it's only a 1.4 but so was my 307 and it's bigger but that had more power then this 206. It's struggles to get to 70mph no eml light on any thoughts what this could be?
gazza82
PostPosted: Mon Feb 16, 2015 7:17 am Up
Check the cat/filter ... mine collapsed and blocked the exhaust ... goes quicker now as I removed said cat with a large steel bar and hammer!
glenpring
PostPosted: Mon Feb 16, 2015 9:39 am Up
Anyway of testing of the cat is gone?
gazza82
PostPosted: Mon Feb 16, 2015 10:43 am Up
I had to take the cat section out of the exhaust .. but then it was obvious.
If you remove the heatshield you might be able to knock it hard enough to make the cat wobble and bounce around, but it's well steadied with bolts to engine.
It shouldn't take to much to remove ... I only lost a small amount of skin and blood! Smile
glenpring
PostPosted: Mon Feb 16, 2015 2:05 pm Up
Decided to take the cat off its not blocked because there is nothing inside it lol. Pulled the plug on the mass air flow and it seems to have power again, so I'll be ordering a new maf tomorrow.
PostPosted: Mon Feb 16, 2015 2:29 pm Up
well it worth checking the turbo,take the hose off,and move the shaft,to see if you got a broken turbo shaft or not,also it worth checking the fuel filter brand,as some rubbish brands make such a problem.
glenpring
PostPosted: Mon Feb 16, 2015 4:06 pm Up
Well I unpluged the maf and it's sorted the problem so I'll try a new one first then I'll do a service and change the fuel filter as well
