Online Now [310]:
Visitors: 309
Today: 25765
Total: 156019201
Forums › The Car › 206 Talk › Scared to program new key.
Forum Index › 206 Talk
greenpug2222
PostPosted: Mon Feb 16, 2015 2:46 am Up
Hi,
I'm looking for a bit of reassurance and tips........
I need to program a new key ( chip only version) as I only have the one push button type at the moment and I thought a spare would be handy.
So I bought the software and leads ( b version )and programmed it on to my old laptop and its all works with the car. I've read numorous posts about programming new keys but ............. Im nervous I'll screw it up.
Can anything go bad if I mess up on the programming?
Cheers
Joe
why wont you work??????????????????? ARGH F**k it!!!!!
PostPosted: Mon Feb 16, 2015 4:01 am Up
Just follow the instructions on the screen and you can't go wrong.
Presuming you have the alpha numeric security code and the new key has never been programmed to a vehicle before?
efeash
PostPosted: Mon Feb 16, 2015 4:17 am Up
its surprising how quick and easy it is, i had to code a new chip after the mrs lost hers all done in no time.
like macca says just follow the instructions Smile
ash
greenpug2222
PostPosted: Mon Feb 16, 2015 4:50 am Up
Yes I have a new Virgin chip.
I had to get my code from a guy online from another site so I hope it works.
Can I confiem that when asked how many keys I put 2 even though 1 is the original?
ukskater01
PostPosted: Mon Feb 16, 2015 5:09 am Up
Yes as you want the car to recognise two keys. It's very straight forward and the software walks you through the whole process.
PostPosted: Mon Feb 16, 2015 1:07 pm Up
There is always a chance it can go wrong, just make sure you get the key code from PEUGEOT! And not someone onlin
greenpug2222
PostPosted: Tue Feb 17, 2015 4:51 am Up
Hi again,
I've failed at coding a key.
I go through the whole process but it does not recognise the second key then logs a fault which I have to clear.
Could the new id45chip be faulty?
greenpug2222
PostPosted: Sat Feb 21, 2015 9:49 am Up
Well I got a new chip today and if ally managed to program it..... And it works.
However it did leave 2 faults on the bsi which I had to remove.....
Meeee
PostPosted: Wed Feb 25, 2015 11:38 am Up
just wondering what software you need to program a key and where can I get it? Also where can I get a replacement remote key?
greenpug2222
PostPosted: Wed Feb 25, 2015 12:44 pm Up
Depending on age of car either pp2000 ( peugeot planet ) or diagbox. These both run on an xp operating laptop. You will also need a new Virgin chip for the imobiliser and your cars own 4 pin access code.
The program, cables and chip can be found on the likes of ebay etc etc however the cide you should already have or contact peugeot for it. I got me from a 3rd party source.
Hope this helps.
PostPosted: Wed Feb 25, 2015 1:34 pm Up
206 uses Peugeot Planet.
Diagbox will work fine on a 206 as well.
I've got Diagbox version 7.57 running on 32 bit Windows 7 without any need for a XP virtual machine Wink
If your using Diagbox version 7 onwards then make sure your Lexia interface is revision C.
If you go to Peugeot for the security code they will ask for your photo ID & also proof of ownership for the car ( V5C registration document )
