Online Now [997]:
Visitors: 996
Today: 138650
Total: 155231164
Forums › The Car › 206 Problems › Egr valve
Egr valve
Joethepet
PostPosted: Sun Mar 01, 2015 1:46 pm Up
Does a 206 1.1lx have an egr valve? I Had a p0420 fault code. I replaced both lambda sensors but the engine management light won't clear. Tried on a fault reader. Been told it might be the egr valve but I can't find it anywhere in the engine bay. And help is appreciated. Thanx in advance
PostPosted: Sun Mar 01, 2015 2:15 pm Up
No it doesnt
P0420 usually means your cat is failing
PostPosted: Mon Mar 02, 2015 3:00 pm Up
Addaz wrote:
No it doesnt
I agree! What He Said
But before you replace your CAT,There is few things that you need to check other than the Oxygen sensors:
1-Check your coolant temp. sensor if it's working right or not.
2-Check your exhaust system for leakage.
3-the condition of your spark plugs and coil pack.
If all is good,then time for a new CAT.
