Posted: Tue Mar 03, 2015 2:13 pm |
Hey guys,
Anti-pollution fault again. 4th time now.
I need to find out what it is and fix it before my MOT on the 12th.
Cheers.
Posted: Wed Mar 04, 2015 4:05 pm |
does it have to be pp2000, i have a delphi unit which i can put on for £15 if it works. In coventry myself
Posted: Fri Mar 06, 2015 2:04 am |
Have you checked the PP2000 Map,if not,please click on the link below,and check the map
PP2000 Map
Tim
Posted: Fri Mar 06, 2015 3:55 am |
| Timon2210 wrote: |
PP2000 Map
Tim |
Nearest one is Cheltenham. I know as i have checked before.
Posted: Fri Mar 06, 2015 4:20 am |
| Carlos_WR1 wrote: |
| Timon2210 wrote: |
PP2000 Map
Tim |
Nearest one is Cheltenham. I know as i have checked before. |
Cheltenham's quite a drive tbf, I may as we'll pay for the dealer to do it and not waste the petrol...
Posted: Sat Mar 07, 2015 3:42 pm |
Anti pollution can mean your cat has got clogged up. Take a good run about ten or twelve miles at a good speed but use a lower gear than you usually use, this will burn off the crud and clear the fault, try that before anything else
