Online Now [425]:
Visitors: 424
Today: 103242
Total: 155583197
Forums › The Car › Solved 206 Problems › eml light on after a new pre cat o2 sensor
Forum Index › Solved 206 Problems
Project2062014
PostPosted: Fri Mar 06, 2015 9:19 am Up
Is this just a faulty o2 sensor ?
johnpidge
PostPosted: Fri Mar 06, 2015 10:55 am Up
try disconnecting the battery for 30 minutes to reset everything before you go that route
John
Project2062014
PostPosted: Fri Mar 06, 2015 11:27 am Up
It resets only to return the faults .
I have changed the lambda sensor pre cat only a week 10 days ago ..
reason was the thread had gone and blew out the pipe .
I'm going to change the sensor I think.
PostPosted: Sat Mar 07, 2015 10:58 am Up
It's a faulty Lambada sensor,needs to be replaced,as the heater in that sensor is not working.
MUHAMED
PostPosted: Sun Mar 08, 2015 8:06 am Up
or check the contacts / wiring. Measure if there is a voltage on the heater terminals of lambda sensor.
maybe there is a fuse blown that supplies lambda sensor with voltage for heating.
Project2062014
PostPosted: Wed Mar 11, 2015 6:41 am Up
New senor bosch all works well .
PostPosted: Fri Mar 13, 2015 2:03 pm Up
Glad that you got it fixed,always buy a good brand when it comes to such important items Wink
