Forums › The Car › 206 Problems › 1999 V-Reg 206 GLX Remote Central Locking problem |
Posted: Sun Mar 08, 2015 6:25 am |
we have a problem with our 3 door 1999 V reg 1.4GLX 206
We have to lock each of the two doors manually and we cannot lock the rear hatch either so its unlocked all the time.
The fob works, we can hear a relay clicking behind the dash when the key fob or either of the door pins is pressed, but, the car never locks.
We have to manually lock the doors with the key and leave the boot open which is not ideal.
I would be surprised if all 3 locking actuators have failed, is there a central earth point, fuse, ecu for the central locking that would cuasing all 3 to fail at once on a 1999 206?
So, where best to start checking?
Any advice and pointers here greatly appreciated.
Posted: Sun Mar 08, 2015 12:49 pm |
Check the Fuse No. 16 (30 A) which is located under the steering wheel
Posted: Mon Mar 16, 2015 3:41 am |
Hi, thanks for the reply,
I checked the owners handbook and found fuse E for the 'openings' was mising,
I fitted another fuse which now the motors operate but unlock straight away, this must of been why a previous owner removed the fuse.
I disconnected all the door and tailgate wiring looms and tried operating the locking system to indicate which door might be faulty which proved no differnent and still locking nd instantly unlocking.
Any ideas?
