Latest: sparrowdclxvi
Overall: 17139
Online Now [118]:
Visitors: 117
Today: 16020
Total: 113256438
Forums › The Car › 206 Problems › 206 2003 Multifunctional Display issues and radio stays on
christopher
PostPosted: Tue Mar 10, 2015 11:48 am Up
I have a 1.1 206 2003
Today after washing my car the mfd has decided to not work you can hear it beeping when i open the door with the engine on but nothing on the actual display?
Also after installing a Car stereo the thing stays on after i turn off the ignition why is this?
thanks for any advice
PostPosted: Tue Mar 10, 2015 2:59 pm Up
First one, telling you the key in the ignition
Second one read this
christopher
PostPosted: Wed Mar 11, 2015 3:36 am Up
What you mean as I'm on about the display that shows the temperature and when the door is open no longer works
Also I know about the red and yellow wires swapping and my radio stores all channels fine but doesn't turn off when ignition is off
Carlos_WR1
PostPosted: Wed Mar 11, 2015 5:28 am Up
Have you definitely wired the power to the radio through the ignition, if its wired to a permanent live then it will not go off when the engine is switched off.
Also when ignition is switched off, some stereos can stay on for a few mins after have you stayed in the car for a few mins after switching the ignition off to see if it eventually switches off?
christopher
PostPosted: Wed Mar 11, 2015 6:36 am Up
That's exactly what is happening it stays on for several minutes after the ignition is off. Is it just how the 206 is?
PostPosted: Wed Mar 11, 2015 7:25 am Up
From the link I posted earlier
Quote::
Q: My headunit stays powered after I leave the car?
A: You car's BSI will turn off after 3 minutes as long as no doors and so on are opened. When the BSI turns off, so does the HU.
christopher
PostPosted: Wed Mar 11, 2015 7:40 am Up
thank you, just couldn't look before as I was on my phone. So I now know the radio is normal.
Now to sort out the display. Any ideas?
christopher
PostPosted: Wed Mar 11, 2015 5:12 pm Up
Now the multifunctional display is randomly coming on when the car is locked
Does anyone know what's going on?
christopher
PostPosted: Sun Mar 15, 2015 10:38 am Up
Anyone have any ideas?
