Latest: sparrowdclxvi
Overall: 17139
Online Now [151]:
Visitors: 150
Today: 12280
Total: 113252751
Forums › The Car › 206 Problems › Front wing
Front wing
N3tbloe
PostPosted: Thu Mar 26, 2015 7:42 am Up
I want to remove my front right wing on my 02 pegeout 206.
Is it easy and just bolted in or do I need a mechanic for that?
I just want to fix a dent* out the wing a bit
PostPosted: Thu Mar 26, 2015 10:21 am Up
Why do you need to remove it if you are only going to buff it?
It's a simple DIY job to remove. There is a guide somewhere on the site, you might have to use the search function to find it.
N3tbloe
PostPosted: Thu Mar 26, 2015 2:24 pm Up
I used the wrong word,sorry.
I ment fixing a dent on the wing
PostPosted: Thu Mar 26, 2015 2:26 pm Up
Ask a smart repairer for a quote first before you go through the hassle of removing the wing.
Triggerfish
PostPosted: Fri Mar 27, 2015 6:20 pm Up
The dent can be pulled out by drilling a small screw into the dent and pull the screw, then make the necessary sanding/filling/sanding and painting.
To remove the wing:
1. remove wheel.
2. remove 2 plastic arch under wing. (front & rear: 2 screws , 2/3 plastic fixings)
3. lift bonnet, remove 2 bolts.
4. remove front light. (3 screws, unplug light bulbs)
5. remove 2 bolts/nuts towards the front of the wing.
6. use pliers to release 2 plastic connectors at front wing end & front strip (above bumper) (do this from under the bumper)
7. loosen bolt towards door/wing/indicator level (reach from inside wheel arch) (bottom one is slot fit only)
8. unlink side indicator.
The wing can now be taken off the car by lifting up the door end side and detach links/connections from the front end.
206: 1.1L, 2002.
