Online Now [382]:
Visitors: 381
Today: 96419
Total: 157285696
Forums › The Car › 206 Problems › Airbag fault
Airbag fault
ukskater01
PostPosted: Mon Mar 30, 2015 2:15 pm Up
Hi, a friend at work brought a V reg 206 in for MOT. It failed on a number of things which I've repaired but the airbag light fault is confusing me slightly.
From what I can see underneath the car has had a back end smash and the boot floor was badly pumped out :/
I stuck pp2000 on it and got faults with both seatbelt pre tensioners had triggered, open circuit, and a triggered seatbelt fault. The strange this is the seatbelt's work fine. I'm guessing they may have been replaced.
Does the airbag ecu need to be replaced or could there be a fault with wiring,etc.
Thanks for any info
Leegsi
PostPosted: Mon Mar 30, 2015 3:10 pm Up
The airbag ecu will need the crash data clearing
ukskater01
PostPosted: Mon Mar 30, 2015 3:18 pm Up
Do you know how this can be done?
Vexs
PostPosted: Mon Mar 30, 2015 3:26 pm Up
You will have to remove it and send it off to be done, PP2000 can't access it neither can most of the other generic code readers tbh.
My GTI 180
My Old 1.4 8v
PostPosted: Mon Mar 30, 2015 3:28 pm Up
For what a working / unfired non plexed 206 airbag ecu can be picked up for it would be cheaper to just replace it.
ukskater01
PostPosted: Mon Mar 30, 2015 3:45 pm Up
That's what I was thinking, do I need to get the same year or same part number etc?
PostPosted: Mon Mar 30, 2015 4:16 pm Up
Seat belts can work fine but can have been triggered in the ecu
Or just failed in general
