Forums › The Car › 206 Talk › Tyre Size |
Posted: Thu Apr 02, 2015 4:37 am |
2005 HDI GTI
All round my pugget I have 205/45/16
I can't find a very good selection of tyres compared to my 15s on my MR2.
I only need rear tyres though, so is there any other sizes I could use to broaden the choice? I.e. 215/45/16, 195/45/16?
Cheers
Posted: Thu Apr 02, 2015 7:36 am |
Go here www.anycalculator.com/tiresize.htm
Plug the numbers in, so long as the difference is less that 2% then you are golden
I'd be careful going much wider, as the tyre will start to catch on the arch, unless you have spacers...
| 1.6HDi. Pull like a train. Smokes like one too!
No Smoke, No Poke! | |
Posted: Thu Apr 02, 2015 8:46 am |
Good selection? In a particular price range? Most high performance tyres start at 17" these days. Goodyear F1 Assymmetric 2s come in 16" sizes and are a decent tyre.
Posted: Thu Apr 02, 2015 3:18 pm |
Posted: Sat Apr 04, 2015 2:37 am |
Are they meant to be 205s? On some sites I've looked at The standard tyre size on that alloy is meant to be 195....
Can I really go thinner on the rear, will it not have a effect as the fronts are 205?
Posted: Sat Apr 04, 2015 7:09 am |
Won't make any difference, on the race car I run 205 on the front and 195 on the rear
Posted: Sat Apr 04, 2015 8:47 am |
Only GTI fitted with 195s are those with 15" wheels and early cars that had Nimrod fitted as an option as part of the SP kit.
Any car fitted as standard with Nimrods had 205 tyres.
