Online Now [387]:
Visitors: 386
Today: 164525
Total: 155457462
Forums › The Car › 206 Problems › Excessive brake pedal travel
razza987
PostPosted: Thu Apr 09, 2015 7:57 am Up
Hi guys,
My 206 race car has excessive brake pedal travel. I need to depress the pedal a long way before any braking action starts. Once the brakes are engaged they are strong and the pedal is quite firm, so I don't believe it's air in the system.
I have no ABS.
Any thoughts on what it might be? It's been like this for the last 3 years but it's hard to drive fast when you're not 100% confident with the brakes. I have to get off the gas early due to the time it takes to find the biting point.
Cheers,
Raz
206 GTi Circuit Racer
Tricolore Trophy
www.trackattackraceclub.com
ukskater01
PostPosted: Thu Apr 09, 2015 8:54 am Up
I would say the discs are worn which creates extra travel for the pistons, feel the edge of the discs for a lip. I would replace the discs, pads and bleed the system as brake fluid should be replaced every 2-3 years because of water absorption.
razza987
PostPosted: Thu Apr 09, 2015 5:04 pm Up
I appreciate that you're trying to help, but I was hoping for something more 206-specific.
Piston travel doesn't increase as discs wear.
Tricolore Trophy
heyziq
PostPosted: Fri Apr 10, 2015 12:23 am Up
Need larger master cylinder.. I feel the same way too
heyziq.com
