Latest: flipflap
Overall: 17140
Online Now [553]:
Visitors: 552
Today: 60517
Total: 113860524
Forums › The Car › 206 Problems › Peugeot Fuel 2.0 HDI Gauge Fault
pughdi2003
PostPosted: Fri Apr 10, 2015 6:38 am Up
Hello All,
I have a 2.0 HDI 2003 D Turbo but the fuel gauge seems to do whatever it feels like. I filled the tank with approx 50 ltrs and it only showed 3/4 full then went out in the morning and showed a full tank only done about 70 miles now showing 1/4 of a tank any ideas could it be the fuel sender unit or any common faults to be aware of ?
When I purchased the car the fuel light was on I had only put £10.00 of fuel in before so could it be a sticky float ?
Thank you
206HdiGti
PostPosted: Fri Apr 10, 2015 9:56 am Up
Mine does that sometimes.
Think it's the float valve in the tank, it sticks sometimes.
If you go over a bump it may come free and give a correct reading. Mine has done it so many times, I write down how much fuel I buy and then work out the minimal fuel I'll get based on 50mpg lol
pughdi2003
PostPosted: Fri Apr 10, 2015 11:19 am Up
PostPosted: Fri Apr 10, 2015 1:19 pm Up
Check the tank sender.
This is a known BSI software bug that affects the fuel gauge, if the sender is ok then might be time to visit Peugeot & get the software updated.
