Latest: ArtistKS
Overall: 17145
Online Now [198]:
Visitors: 197
Today: 36121
Total: 116129264
Forums › The Car › 206 Problems › major problem
major problem
jakeyboy243
PostPosted: Thu Apr 16, 2015 10:41 am Up
hi can anyone tell me why when i drive my car that the front left hand side wherl keeps juddering i have recently had new pads and disc could it be that the brakes have been installed wrong if anyone has had this problem and knows how to fix it that woulf be great:)
Seatock789
PostPosted: Thu Apr 16, 2015 10:49 am Up
Worn wheel bearing? If you lift the wheel off the ground, grab it with 2 hands and try moving it from side to side & top to bottom. Worn bushes, drop links etc, could be any number of things.
My brother-in-law had a juddering problem with his brakes so we replaced everything we could and it still happened, we took it to a garage and it turned out that the drive shaft was slightly bent.
PostPosted: Thu Apr 16, 2015 12:42 pm Up
I presume you meant discs so that should be fine,
maybe the wheel need balancing.
jakeyboy243
PostPosted: Thu Apr 16, 2015 2:49 pm Up
Ive checked the wheel bearing snd there is no play in the wheel and and how would i be able to tell if bushes and that are worn out and the wheel actually stops spinninall together and yerh i meant discs
