Latest: dreyfalon
Overall: 17121
Online Now [521]:
Visitors: 520
Today: 38663
Total: 97564984
Forums › The Car › 206 Problems › ABS Light
ABS Light
Big_Aly
PostPosted: Sat Apr 18, 2015 9:27 am Up
My Abs light has appeared on the dash of my 206 gti 138 so took it down to the local garage for a diagnostics.
The faults come back as
Rear left wheel speed sensor faulty (which i can replace myself)
Does the rear also have abs rings?
And also
Abs pump motor/Engine relay faulty
Where is this relay?
Sorry if a dumb questions, but thought i would ask the pro's on here Very Happy
PostPosted: Sat Apr 18, 2015 3:21 pm Up
The Rear wheel do have ABS rings,but it's a built in the wheel bearings itself.
About the relay for the ABS,it's located in the engine bay fuse box.
Big_Aly
PostPosted: Sun Apr 19, 2015 4:55 am Up
OK thanks for that, I will give it a good clean up aswell then.
Regarding the abs relay all I can find is this
www.ebay.co.uk/itm/PEU...0539527865
I cannot see anything that looks similar in the engine fuse box area?
If someone can point out where this goes or if this is what I need?
PostPosted: Sun Apr 19, 2015 3:07 pm Up
Check with Peugeot. Might be cheaper.
Big_Aly
PostPosted: Mon Apr 20, 2015 4:47 pm Up
Yeah I'll be ringing them tmoz, as I'm still uncertain if that's the part I need.
