Hello, my key seems to be getting stuck slightly above position 2 which is occasionally causing the starter motor to stay on after starting, and meaning interior electronics are off/getting low voltage until I physical turn the key back the where it should be. Do I just need a new ignition switch or will I need a barrel too? And is there I guide for getting the switch off the barrel? I was able to work out how to hey the barrel out but I couldn't get the switch off it.
