Latest: tebas93089
Overall: 17179
Online Now [383]:
Visitors: 382
Today: 57138
Total: 137908351
Forums › The Car › 206 Problems › Flashing Engine Management Light
Spotfist
PostPosted: Fri Apr 17, 2015 5:02 pm Up
Hey all,
As the heading suggests, my engine management light has started flashing, after a load of searching the net and here I have come across the issue with everyone suggesting it's down to a packed up coil pack or needs a new set of spark plugs.
The thing is that I don't seem to have any noticeable loss of power, the light flashes randomly, could it be a spark plug on it's way out? Just wanted to know if a loss of power is always experienced or if the power loss is still to come or something worse?
ps. It's a GTI 130 99'
PostPosted: Sat Apr 18, 2015 1:24 am Up
No point guessing what the light means.
Get it connected to a diagnostic machine and have the codes read, ideally with it being a 1999 plate connect to Peugeot Planet as an EOBD reader may not work.
Until the codes are read and you have been given a general direction of where the fault lies, you could end up throwing money at parts that don't need replacement.
Hawkers
PostPosted: Sat Apr 18, 2015 3:05 am Up
According to the handbook if the light is flashing then you risk damage to the catalytic converter.
I have Peugeot Planet/DiagBox.
Previous Car: Peugeot 206 1.4
Now: Peugeot 207 1.6 VTi 120 Sport
Spotfist
PostPosted: Sat Apr 18, 2015 11:41 am Up
Cheers, does it say what the problem is? It is really intermittent and stopped on the way home today...
Hawkers
PostPosted: Sat Apr 18, 2015 12:12 pm Up
Honestly you need the codes read, but could be anything to do with the injection, ignition or emission control system.
Spotfist
PostPosted: Sat Apr 18, 2015 12:37 pm Up
Cheers for that, Im taking it into the garage on Monday. Fingers crossed it's nothing too serious. The car seems a bit rough on idle so I hope it's just spark plugs.
Spotfist
PostPosted: Wed Apr 22, 2015 12:23 pm Up
update
So i had the codes read today, £54.
Two errors cropped up
P0606 Engine control unit and P0262 Injected fuel quantity cylinder 1 too high.
Guy at the garage suggested replacing the injector at £120. I don't really have the cash at the moment do wondered if anyone knew how easy it was to do as looks easy enough...
oldskoolz
PostPosted: Thu Apr 23, 2015 9:29 am Up
Spotfist wrote:
update
not hard at all, just be careful not to spill fuel everywhere lol
Black 206 Gti. Soon to be 2.2
Spotfist
PostPosted: Thu Apr 23, 2015 11:41 am Up
Cheers for the info, I was thinking of maybe replacing the spark plugs first as this seems like an even easier job, and reading up it could be the plugs causing the issues.
PostPosted: Tue Apr 28, 2015 11:59 am Up
The codes have given you the answer. Injector.
If you want to do easiest job first fit a new battery.
Next easiest after that is probably air filter.
Sorry, easiest is to check tyre pressure.
I hope you realise this is tongue in cheek!
Spotfist
PostPosted: Thu Apr 30, 2015 3:46 pm Up
Lol or I could just put some fuel in and see if that helps? i should have just said i wanted to replace the spark plugs just to be happy it's done, it's an easy and cheap job to do before pay day Wink
