Online Now [561]:
Visitors: 560
Today: 100572
Total: 156978519
Forums › The Car › 206 Talk › Toyo 206 180 straight through pic.
Forum Index › 206 Talk
Project2062014
PostPosted: Thu Mar 12, 2015 8:02 am Up
might be a problem to fit or it might not. Only one way to find out. Will install when time
JordHaze
PostPosted: Thu Mar 12, 2015 9:25 am Up
How much did you pay for it? I'm after a new exhaust myself Smile
My 206 Project Thread
Project2062014
PostPosted: Thu Mar 12, 2015 11:50 am Up
Too much boio that's how much.
Not the best fitment for the joints as it's blowing from the back box . Lines up perfect.
I'm just addressing the 63mm inlet to the back box & the 60mm pipe toyo expect you to Fit. .
Andrew
PostPosted: Thu Mar 12, 2015 12:53 pm Up
Is the 180 a 63mm bore as standard?
My 206 thread
www.detailedbyandrew.com
206gt160
PostPosted: Thu Mar 12, 2015 12:59 pm Up
Is it a universal kit?
Looks better than bike exhaust monstrosity that you previously had on.
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
Project2062014
PostPosted: Thu Mar 12, 2015 4:15 pm Up
180 is a 60mm bore standard.
Project2062014
PostPosted: Thu Mar 12, 2015 4:24 pm Up
It was listed on ebay I've not seen one before with a straight through middle. It is 3 sections cat back. It's loud .
I welded a extra inch of 60mm pipe on the end of the exhaust to get the back box to fit perfectly .. Toyo pipe is thin & under 60mm.
Project2062014
PostPosted: Thu Mar 12, 2015 4:26 pm Up
60mm pipe to show the gap. Was worse with the toyo pipe.
Project2062014
PostPosted: Thu Mar 12, 2015 4:28 pm Up
I used the extra pipe to get a good seal with Clamp. also positioned the exhaust tip exactly where I wanted them.
Project2062014
PostPosted: Thu Mar 12, 2015 4:35 pm Up
I'm sure I welded a 62mm pipe on Tbh. I cut it off a pipe that fits a 60mm pipe sleeve.[http://s1374.photobucket.com/user/benjv85/media/Mobile%20Uploads/20150312_173015_zpsp6pektyj.jpg.html]
[/URL]
Schumi
PostPosted: Wed Apr 29, 2015 2:47 pm Up
Where did you get this exhaust pipe ? I want that to.
2005 206 RC RED
Project2062014
PostPosted: Wed Apr 29, 2015 2:53 pm Up
It's a one off From Toyo sports
I am willing to sell it to you if you are interested.
206gt160
PostPosted: Wed Apr 29, 2015 3:04 pm Up
Hey pal What price is it going for and also why are you selling it.
Project2062014
A&W, German make I brought off ebay Lowered 50mm . Red springs
I wouldn't go 60mm. It will scrape Too much.
On country roads with dips and bumps it scrapes . I only have trouble with one speed bump and the front bumper scrapers alot ..
The sump is the lowest point so be carefull..dropped 50mm all round . On 17's
PHONE FOOKED WAS NOT EVEN ON THIS THREAD WTF !!
EDIT : Price make me a sensible offer .. its 63mm all the way . can supply the clamps aswell . Im selling due to having 3 complete exhaust systems .. I could do to clear the space as I'm moving house soon ..
The exhaust is fitted to my car at this moment in time ..
206gt160
PostPosted: Wed Apr 29, 2015 3:09 pm Up
Wrong post that project
