Latest: dreyfalon
Overall: 17121
Online Now [566]:
Visitors: 565
Today: 37896
Total: 97564218
Forums › The Car › 206 Problems › PP2000 - Abs/Dam
PP2000 - Abs/Dam
Big_Aly
PostPosted: Sun May 03, 2015 11:52 am Up
Hi i purchased a pp2000 put on my car as the abs light was on the dash and it asked for a dam number.
The number on the door said 906583
So would that make the dam number 90658 ?? Not to sure about this.
The reason i ask is i had a permanent fault with the abs pump after putting that dam in.
The ref it gave me was 9632539480 for the part
But my abs pump that's on the car says 9630135080
Kinda confused me as different
Any help would be appreciated.
tRiCk
PostPosted: Sun May 03, 2015 12:06 pm Up
Doesn't matter tbh I never check it, just put 9999 if your not doing downloads etc
Big_Aly
PostPosted: Sun May 03, 2015 12:31 pm Up
Yeah im not doing downloads just a straight global scan.
The error come back
Abs or Esp Ecu
Permanent Fault Pump motor
206Teves_mk20e
Psa ref: 9632539480
Supply ref:09
But my abs pump on the car number is 9630135080
What one do i replace it with? or any other ideas what to check?
MrWhite
PostPosted: Mon May 04, 2015 11:45 am Up
swap the abs pump Like for like the numbers on the abs its self
My 206 Project Thread
Big_Aly
PostPosted: Mon May 04, 2015 1:09 pm Up
Will there need to be any reprogramming done or will it be just a straight swap as havnt got a clue. Shocked
The ones I've seen for sale is the pump, with the black bit on the side with the pins ECU?? Would I need the whole unit is this how they come?
PostPosted: Mon May 04, 2015 2:21 pm Up
You need to do configuration for the ABS unit after you replace it,using the PP2000 ofcourse.
Big_Aly
PostPosted: Mon May 04, 2015 3:46 pm Up
Is the configuration easy to do? What does it involve. Sorry for being dumb but gunna be the first time doing this so like to be all prepared. Thanks
Leegsi
PostPosted: Sun Jun 14, 2015 2:08 pm Up
Never needed to do anything when I swapped mine like for like
gpvecchi
PostPosted: Mon Jun 15, 2015 2:41 pm Up
Your OPR is 9085 (your car was born on 23 September 2001). The 83 is the factory of your 206. Don't look at the number on the pump, as it's a producer P/N; this is trans-coded into Pug number (the new ones are like 9632539480, the old ones are like 1109AY).
Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror
