Online Now [1306]:
Visitors: 1305
Today: 415116
Total: 153811139
Forums › The Car › 206 Problems › air bag module trigger 2
touche60
PostPosted: Sat May 16, 2015 2:17 pm Up
can some one help as I have tried to get light out and it keep's coming up with Permanent fault level of driver module trigger 2 open circuit, I have been using pp2000 on laptop and got a new srs. I have a 54 1.4 hdi.
PostPosted: Sat May 16, 2015 2:24 pm Up
Has the airbag been removed recently?
The plugs can be difficult to get in & out the sockets.
Other then that I would suspect a Com2000 fault as its in the age range for a dodgy Com.
touche60
PostPosted: Sat May 16, 2015 2:36 pm Up
I think it was a light n/s front knock and bag has gone off, I've had a look today and all is right, plug's are tight and in the right place the ribbon is still in one peace. the airbag has been replaced.
PostPosted: Sat May 16, 2015 2:53 pm Up
If the airbag has been fired then you need a new airbag ecu & pair of front seatbelts as the pretensioners should have fired as well.
First time ive heard of a light knock on a multiplexed 206 actually firing an airbag, normally it takes a hefty knock.
PostPosted: Sat May 16, 2015 3:20 pm Up
Sounds like a comms has failed. Level 1 and 2 means how heavy the airbag fires
touche60
PostPosted: Sun May 17, 2015 11:01 am Up
got new comms airbag light is now out thanks allan.
