Posted: Sun May 17, 2015 6:17 pm |
hi. need some help. so today i managed to put a fuse from the audio slot (24) to 24b basically half in 24 and half in 24b the slot above and it sparked. now i have no indicators, electric windows and the wipers turn on, but if I switch them off them carry on and after a while stop in any position HELP please
Posted: Mon May 18, 2015 6:14 am |
If your radio is on F24, I assume you have a pre-plexed model (double-check through the link below).
Try to perform a BSI reset procedure from from www.206info.co.uk/Foru...c/t=20541:
I am not sure about how to disable anti-theft, though I had battery disconnected numerous times, and my car has alarm -- to test - lock then deadlock with small key, then open door with the key and cover your ears
.:Beginners Guide to a 206:. wrote: |
Non-plexed Electrical System
* You may need your radio code upon reconnection
* If your car has a Peugeot anti-theft alarm system, disable this
* Disconnect the negative terminal first
* Disconnect the positive terminal
* Complete intentions
* Now to re-connect, Connect the positive terminal first
* Connect the negative terminal
* Before starting the engine for the first time, turn on the ignition and wait for 10 seconds to initialise the various electronic control units
* Activate alarm system, if you have one
Posted: Mon May 18, 2015 4:38 pm |
I have already tried the reboot but nothing happened. I have been told it may be down to the relays on the bsi. But I tryed to get the bsi out today to have a look and spent 2 hours trying to ge the cover off with no luck. Do you know how to remove the bottom cover from the bsi?
Posted: Mon May 18, 2015 6:14 pm |
Posted: Tue May 19, 2015 2:10 am |
Thanks for that it will hopefully help but I can't actually get the plastic cover that hold it in and protects from feet. Under the dash. It has 2 clips either side which I have undone and still nothing. Thanks
Posted: Tue May 19, 2015 3:44 am |
I got no cover on mines, but I see what you mean,
Haynes manual says "carefully unclip the cover"
The rest of the Internet (including this forum) says to rip it off. Looks like pair of gloves and some lever is in order
Also explains why I haven't got it, probably doesn't come back up It's safe distance from legs, I never got entangled into
ref:
www.peugeotforums.com/...6-a-30192/
www.206info.co.uk/Foru...e+bsi.html
Posted: Tue May 19, 2015 9:43 am |
I was going to smash it the prices last night but I think I will just get the dremmel on it and gently cut it off as it has the connections behind. Thanks for the help will update soon haba
Posted: Thu May 21, 2015 9:51 am |
Thanks for the help . It turn out it was missing a fuse and the mechanic told me I would have to run a new feel from the battery for a permanent live to the radio.
