Latest: heikkisj
Overall: 17126
Online Now [68]:
Visitors: 67
Today: 12480
Total: 100385216
Forums › The Car › 206 Problems › Driver side front seat belt jamming when pulled out to use
bigup
PostPosted: Wed May 20, 2015 11:29 am Up
if i pull it out dead slowly it works for short time, any faster then it locks
this is the seat belt itself not the seat belt locking mechanism
drivers side front on a 3 door 1.4hdi 2003
any ideas what i need to replace?
this? www.ebay.co.uk/itm/PEU...2348ce5064
always any guides on how to remove the existing one to replace?
thanks!
2003 206 1.4 HDi Style 3 Door
bigup
PostPosted: Wed May 20, 2015 3:11 pm Up
ok managed to get it out
i pulled off the non coil side and after having a play is seems this ball bearing bit is not working correctly, its staying in the up position even when the unit is straight (as it would be fitted in the car)
if i pull the yellow level down the belt works fine, it just doesn't stay down
any ideas?
bigup
PostPosted: Wed May 20, 2015 3:20 pm Up
ok took the yellow part out and its still happening, seems to be jamming
will need a replacement Smile
anyone know how much this part is from dealer?
