Latest: Mr-Koekwaus
Overall: 17125
Online Now [132]:
Visitors: 131
Today: 8657
Total: 99368390
Forums › The Car › 206 Problems › Can't get timing belt back on!! - 206GTi RFR
neilneil2000
PostPosted: Sun May 24, 2015 6:46 am Up
I decided to use my bank holiday weekend changing the cam/timing belt. I'm all the way to the point of refitting and I cannot get this thing on for the life of me!
It's a 2.0 EW10J4 engine with the Allen key style tensioner.
I'm pretty sure that my issue is that I just can't get the tension between the crankshaft and the inlet camshaft (via idler). I reckon I am one tooth out. Any tips???
HELP!
PostPosted: Sun May 24, 2015 9:08 am Up
Is the belt over all the cams and pulleys? You can always tension afterwards.
neilneil2000
PostPosted: Sun May 24, 2015 4:38 pm Up
Done!
Tip 1: use plier handles to wedge the belt against the crankshaft and inlet camshaft. This stopped them jumping teeth when I tried to apply tension.
Tip 2: Ensure the tensioner is absolutely at the least tense point. It's hard enough as it is!
2000 (W) 206 GTi pre-plex RFR EW10J4
