Latest: Mr-Koekwaus
Overall: 17125
Online Now [160]:
Visitors: 159
Today: 2847
Total: 99362614
Forums › The Car › 206 Problems › Roof Bars for 3 door 206
life_on_mars
PostPosted: Sun May 24, 2015 3:35 pm Up
Hi, only recently got a 3 door 206, having been used to larger 4/5 door cars - so am a newbie to this forum. Always had roof bars or roof racks for these, which are obviously no problem to fit. I have noticed previous posts on here about roof bars/boxes for 3 doors. I don't want a box, but bars for when I have to take large items to the local tip - only a couple of miles away. As there are no rear door frames to fasten the rear bar to, are they secure? Has any one any recommendations for roof bars only? Thanks
PostPosted: Sun May 24, 2015 4:34 pm Up
The rear bars hook into the rear Window opening and clamp tight when the bolts are done up.
