Posted: Mon May 25, 2015 2:13 pm |
Got a problem with the abs on rear axle, put PP2000 on car and it came back with, Permanent fault wheel sensor signal fault, coherence. Put two new sensors in but the firm I got them from said the info of the reg I give them the axel is drum and not disc. so any info on the problem will be great.
Posted: Mon May 25, 2015 2:19 pm |
Has someone changed the rear beam in the past?
If you want PM the VIN & ill have a look on Peugeot Service box to see what type of rear brakes it rolled out of the factory with.
Posted: Mon May 25, 2015 2:27 pm |
Do not know if it has been changed just got the car ill PM VIN.
Posted: Mon May 25, 2015 2:28 pm |
touche60 wrote: |
Got a problem with the abs on rear axle, put PP2000 on car and it came back with, Permanent fault wheel sensor signal fault, coherence. Put two new sensors in but the firm I got them from said the info of the reg I give them the axel is drum and not disc. so any info on the problem will be great. |
EDit: Odd, why didn't I see the replies, but only the first post...
| Silvermetallic 2004 206 RC | |
Posted: Mon May 25, 2015 2:31 pm |
This 206 originally left the factory with a LUCAS rear drum set up.
Posted: Mon May 25, 2015 2:40 pm |
So does it mean put it back to factory spec or is there something else I can try.
