Latest: Mr-Koekwaus
Overall: 17125
Online Now [132]:
Visitors: 131
Today: 2615
Total: 99362382
Forums › The Car › 206 Problems › power steering pump pipe strong leak through nut
Sim
PostPosted: Tue May 26, 2015 6:55 am Up
I'm away from home, and here in Coventry I lost power steering .
when engine is running the liquid is splurting everywhere from the nut of the U-shaped pipe that screws in on top of the pump.
will get a spanner and redo the nut, probably it's a seal.. if not, hope you can advise some other checks/remedies. trying to avoid servicing my arm and a leg until i reach bristol later today
cheers!
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
PostPosted: Tue May 26, 2015 8:23 am Up
There is a small O - ring on the union.
Sim
PostPosted: Wed May 27, 2015 5:32 am Up
Edward saves the day, cheers buddy!
I fastened the nut, as it got loose due to the split O-ring, topped up fluid and that gave me enough time to reach Bristol safe!
New O-ring (P/N 4006.30) on its way, will be back on road in no time Very Happy
EV
GTC VXR (sold)
