Latest: sparrowdclxvi
Overall: 17139
Online Now [520]:
Visitors: 520
Today: 81260
Total: 112892830
Forums › The Car › 206 Problems › Radiator Bleed valve?
neilneil2000
PostPosted: Sun Jun 07, 2015 6:42 pm Up
I have drained and refilled the coolant in my 206 GTi but I am pretty sure there is still air in the system. The question is, how the hell do I get it out?
Lots of places I look on the web mention a bleed screw on the radiator but I can't find one for the life of me! I know there is one on the thermostat housing and another on the pipe leading to the heater matrix but they are running without air. This is really frustrating me now!
PostPosted: Mon Jun 08, 2015 12:45 am Up
There are only two and you've found them.
neilneil2000
PostPosted: Mon Jun 08, 2015 12:55 pm Up
I still think there is air in the pipe between the top of the radiator and the engine block. How the hell do I get it out?
2000 (W) 206 GTi pre-plex RFR EW10J4
PostPosted: Mon Jun 08, 2015 2:11 pm Up
It will either come out the thermostat housing bleed screw or it will go to the top of the radiator. If it goes to the radiator it will exit through the hose to the coolant reservoir.
PostPosted: Mon Jun 08, 2015 3:48 pm Up
Why do you think its still got air in?
neilneil2000
PostPosted: Mon Jun 08, 2015 4:37 pm Up
When I squeeze the hose it just feels very "airy"
PostPosted: Tue Jun 09, 2015 2:21 am Up
That's will be coolant moving about.
PostPosted: Tue Jun 09, 2015 3:17 am Up
Exactly. If they were rock solid you've got pressure and problems!
