Latest: sparrowdclxvi
Overall: 17139
Online Now [126]:
Visitors: 125
Today: 14064
Total: 113541739
Forums › The Car › 206 Problems › ball joint
ball joint
Go to page Previous  1, 2
PostPosted: Tue Jun 16, 2015 3:26 pm Up
This is how I used to get mine out.
sloposse
PostPosted: Fri Jun 19, 2015 12:40 pm Up
All that will usually achieve is a broken plank and whiplash when you stamp on the floor, its definately easier with 2 people.
I prefer to jack up the leg until just before the spring starts to fight back then get a mate to wobble the leg into position while i negotiate the ball joint into it.
Alone its got to be easiest to undo the wishbone bolts, connect the balljoint then negotiate the wishbone back in. Pain in the a**e, im just about to replace both of mine cant wait lol
PostPosted: Fri Jun 19, 2015 4:51 pm Up
Stamp? It's a lot more controlled than that.
Page 2 of 2
