Online Now [261]:
Visitors: 259
Members: 1
Today: 44404
Total: 155762908
Forums › Tuning, Modification & Legal › Project Cars › Projects 180Gti reincarnation
Go to page Previous  1, 2, 3, 4
David1156
PostPosted: Mon Jun 22, 2015 4:42 pm Up
Project2062014 wrote:
Pop & Bang 206 180: youtu.be/OHzl2U8hwuU
That sounds fooking great! How many people have you scared so far? Laughing
Current: Albi Blue Clio 197
Project2062014
PostPosted: Tue Jun 23, 2015 1:48 pm Up
[quote="David1156"]
That sounds fooking great! How many people have you scared so far? :lol:[/quote
a few .. is epic ..
Project2062014
PostPosted: Sun Aug 02, 2015 11:51 am Up
This is the exhaust i have fitted if anyone wants 1 .
Check out this item I found on eBay: pages.ebay.com/link/?n...64&alt=web
Project2062014
PostPosted: Sun Aug 02, 2015 11:55 am Up
Update new clutch (luk ) & new pads all round .
Need a new box and drivers side driveshaft as ive gearbox leak .
Is fine for now , been damaged before i brought it .
The housing the driveshaft sits in with the plastic mph spondooly on the diff is damaged .
Ive changed the seals but the taper edge the driveshaft sits in is badly damaged .
As if the drive shaft has been pulled up into the top right of the arch and ran . Strange as there is a fixing (guide) on the bottom of the engine mount & it looks fine . Driveshafts not bent but has marks from grinding the alloy housing away .
The box holds about 1/2 a litre of fluid ..;(
Project2062014
PostPosted: Sun Aug 02, 2015 12:58 pm Up
Project2062014
PostPosted: Sun Aug 02, 2015 1:00 pm Up
PostPosted: Mon Aug 03, 2015 1:00 am Up
You can get that housing easily enough, and did you replace both driveshaft seals?
Project2062014
PostPosted: Tue Aug 04, 2015 6:28 am Up
Yes did both seals .
Project2062014
PostPosted: Mon Aug 10, 2015 5:03 am Up
Colour match! I was threatened by the police !
Stated it they would arrest me for careless driving if I parked half on the path a again.
Also stated they had photo's.
Basically someone didn't want me to park out side there house. I pay my road tax & i needed to park for work + it wasn alwsys in the same place. Only 2 week job aswell .
Jealousy !!
Project2062014
PostPosted: Mon Aug 17, 2015 10:19 am Up
Serious bearing fail i think in 1st & 2nd. New gearbox ordered off eBay £140 81, 000 miles on it. More than the one on the car.
I suspect damages caused form an impact(previous owner) & has created play in the diff/box..
Going to stip it down tomorrow & get ready to install the new box . Hopefully its ok .
I do get a slight torque steer. I wonder if the play in diff/box has any control over the torque steer?
Only thing I've not replaced so far is the engine & Windows.
& a few bushes. .
Project2062014
PostPosted: Mon Aug 17, 2015 10:24 am Up
Damage look like it's been pushed or pulled from the inside?
As the fragments of alloy were pushed to the outside of the housing .creating a ruff lip. I'm thinking it's internal play causing the drive shaft to move.
Project2062014
PostPosted: Fri Aug 21, 2015 9:55 am Up
Page 4 of 4
