Online Now [1045]:
Visitors: 1045
Today: 140472
Total: 151921356
Forums › The Car › 206 Problems › Gearbox leaking
Gearbox leaking
liam1988
PostPosted: Thu Jun 25, 2015 1:00 pm Up
Went to have a look under the car at the track rod and track rod ends because of the advisory I have that there was play the steering track rod inner joints and noticed my gearbox was covered in oil, I'm guessing it's a leak, anyone else had a gearbox leak and find the best way to fix it?
Liam
Smile
PostPosted: Thu Jun 25, 2015 1:11 pm Up
Driveshaft oil seals are favourite place for a leak.
Clean the mess down so you can get an idea where the leak is actually coming from.
cainw1
PostPosted: Thu Jun 25, 2015 2:50 pm Up
Also just because the gearbox is covered in oil, any oil leaking from the top of the engine is likely to drip down and over the gearbox. Just a tip as mine had oil on gearbox and it was the rocker cover gasket.
