Forums › The Car › 206 Problems › Rear Suspension VERY Stiff...? |
Posted: Fri Jun 26, 2015 2:48 pm |
Hi all,
Car is a 2002 GTi 138 - it is lowered on the rear and the rear has always been stiff/harsh due to this but recently however it's become un-bearable - my assumption is the shock absorbers however on inspections there's no leaks....
Question is could it be anything else I could rule out before just changing the shocks?
Thanks in advance
Posted: Fri Jun 26, 2015 3:27 pm |
Remove the dampers and see if the suspension moves any easier if you push up and down on it.
Posted: Sat Jun 27, 2015 5:20 pm |
jack it up on the sills then see if the trailing arms move or even hang down, if its stiff or any in n out or forwards n backwards movement it could be time for a new rear beam
Posted: Sun Jun 28, 2015 4:51 am |
Just jacking it up (jacking by the sills ruins them by the way) without removing the dampers won't tell you if it's the dampers or axle bearings at fault.
Posted: Sun Jun 28, 2015 12:45 pm |
Why are the jacking points on the sills then? Silly peugeot
