Online Now [981]:
Visitors: 981
Today: 104968
Total: 150959019
Forums › The Car › 206 Problems › help with gti ecu
help with gti ecu
pumba
PostPosted: Fri Jun 26, 2015 3:43 am Up
Hey guys I did an engine conversion using a rfr gti but the ecu had some burnt pins so I had to change it. I replaced the ecu with a set out of a rfn not realising the difference. The car goes well but its running rich somtimes an seems really greedy on fuel also a bit lumpy on idle almost like a slight misfire. Can rfn ecu bsi ect be used on an rfr an will I need to fit a second lambda sensor, as my car only has one but have read the rfn has 2 so could this be the problem also eml is on permanent Peugeot planet says no fault found but my mate new snap on comes uo with lambda sensor heating circuit rear ive fitted new plugs (boch platinum) tried a new coil pack an tried a icv from a mates car that runs perfectly any help would be appreciated thanks in advance
PUMB@206
pumba
PostPosted: Thu Jul 02, 2015 4:56 pm Up
Even tho there was no comments or suggestions just thought id say its all sorted know an running perfectly so problems solved thank god
PUMB@206
Sim
PostPosted: Thu Jul 02, 2015 6:46 pm Up
What was it? Might be curious for some Smile
EV (roadtripper)
Jag S(crapped)- & X-Type
GTC VXR (sold)
pumba
PostPosted: Fri Jul 03, 2015 10:39 am Up
Took it my mates garage he specialises in french cars lol he got all the same software an diagnostics as peugeot left him to sort it out only took about an hour .rather than trying to fix it myself I should of just took it him as he always tells me to drop it in an he'll sort it but I never listen lol plus he never charges me except cost of parts wich is trade price so bonus
PUMB@206
Sim
PostPosted: Fri Jul 03, 2015 11:01 am Up
lol fair play, enjoy the joyride!
EV (roadtripper)
GTC VXR (sold)
