Latest: Worthy967
Overall: 17143
Online Now [549]:
Visitors: 548
Today: 103814
Total: 114528910
Forums › The Car › 206 Problems › Engine vibration after clutch change
andymaw11
PostPosted: Sat Jul 04, 2015 3:08 am Up
Hi, I have a 2.0 HDi. I few months back the clutch went and had to get it replaced. According to the invoice they replaced the clutch, guide tube and clutch fork.
Since then there's been a huge vibration from the engine when on the bite, particularly in the lower gears.
I took it back to the place that replaced the clutch for them to check. They assured me that it's nothing to do with that and they reckoned it was the engine mounts that are causing the problem. Took it for an MOT yesterday though and the guy said it could be a cylinder (can't remember which!) or damper. Seems odd to me that it was fine before the clutch was replaced.
Has anyone got any better ideas on this or what I should do to get it sorted?
Cheers in advance.
HueyLions
PostPosted: Sat Jul 04, 2015 2:01 pm Up
Just a thought...Does your car have a dual-mass clutch system?
If so it could be the dual mass plate, like I say..it's just a thought.
andymaw11
PostPosted: Sun Jul 05, 2015 9:35 am Up
Honestly, I wouldn't have a clue! I'd have to ask when it's in for a service I guess.
PostPosted: Sun Jul 05, 2015 1:30 pm Up
No it wont have a duel mass flywheel. I would check your engine mounts, especiually the lower mount. If they look ok then I would look into having the slave cylinder bled or replaced on the clutch. Not to hard a job.
andymaw11
PostPosted: Wed Jul 08, 2015 12:27 am Up
Will do, thanks for the advice
