Latest: Worthy967
Overall: 17143
Online Now [576]:
Visitors: 575
Today: 173323
Total: 114296754
Forums › The Car › 206 Problems › Air con troubles :(
Air con troubles :(
l3ighl3igh
PostPosted: Tue Jul 07, 2015 8:07 am Up
Hello again. Have scoured the forums but not found anything.
2002 206 gti
My air con died, not entirely sure but the low speed cooling fan died around the same time. Only noticed cooling fan was not working because it wasn't coming on with the a/c and the clicking sounds stopped. Sorted the cooling fans - now working as they should. Air con however is still not working.
Had an a/c service done today, re gased, no leaks, pressure is fine and fuses are good.
The guy said it required further investigation but could be the pressure switch, relay, sensor or the compressor is dead and quoted £600 to replace. That is not going to happen but I would like to have my dad check those other things for me.
Could someone point me in the right direction of where to find these things, and anything else that would be worth checking before I resign myself to open windows, noise and blowy hair Wink
Reading other threads, I notice people saying when they press the a/c button they get a green light. I dont see a green light and I'm not entirely sure I ever did, even when a/c was working?
Any suggestions, help is much appreciated Smile
PostPosted: Tue Jul 07, 2015 4:08 pm Up
You should here the ac compressor kick in when you turn it on, this is usually accompanied by an initial drop in revs till the alternator takes up the load.
PostPosted: Tue Jul 07, 2015 10:30 pm Up
Is your blower motor working fine?as only the A/C works when you turn the blower on,even if the A/C button is active
l3ighl3igh
PostPosted: Wed Jul 08, 2015 2:09 am Up
Thank you both. As I said, the compressor does not kick in. There are no clicking sounds, no change in the revs. I am not going to replace the compressor as I dont feel it is worth the cost, however I am trying to pin point if there is perhaps something else that could cause the compressor not to kick in.
What do you mean by blower motor? If you mean blowing air out the vents, yes, I'm getting air blowing out the vents on all speeds.
Thanks again!
mtempsch
PostPosted: Wed Jul 08, 2015 9:47 am Up
Lack of gas in the system, sensed by a pressure switch (which could also fail, making the systen think there's no gas, despite there actually being sufficient gas in the system)
Silvermetallic 2004 206 RC
l3ighl3igh
PostPosted: Wed Jul 08, 2015 12:02 pm Up
Thank you! Any idea's where we would locate this pressure switch?
mtempsch
PostPosted: Wed Jul 08, 2015 1:00 pm Up
Sorry, no further than 'follow the air-con pipes around...'
Google or eBay will give you how it looks.
PostPosted: Wed Jul 08, 2015 2:09 pm Up
Read the fault codes. One should show up for a pressure switch.
