Online Now [530]:
Visitors: 529
Today: 42432
Total: 156395188
Forums › The Car › 206 Talk › GTI 180 engine swap =]
Forum Index › 206 Talk
shaunbrook7104
PostPosted: Tue Jul 14, 2015 1:37 pm Up
So I'm looking to swap out my engine for another 206 GTI180 but a 2004 plate and mine is a 2003.
The crank pulley might be different, some are key way and some have a 4 bolt pattern like mine and its 2003.
Is it possible to use an engine with a different crank pulley at all? can I put the 4 bolt pulley on the 2004 engine which may have a key way?
I just prefer the 4 bolt system as its harder for the engine to become un-timmed when changing the timing belt.
Cheers in advance =]
PostPosted: Tue Jul 14, 2015 4:05 pm Up
The crank is different on each engine.
shaunbrook7104
PostPosted: Wed Jul 15, 2015 6:28 am Up
Is it an entirely different crank or just the pulley?
Just want to clarify before going to all the work of a rebuild thats all Smile
Will it affect the ECU and the Crank Position Sensor at all been a diffrent year and crank. It's only 1 year older Razz
