Latest: heikkisj
Overall: 17126
Online Now [58]:
Visitors: 57
Today: 13982
Total: 100386701
Forums › The Car › 206 Problems › New recon rear axle - strange noise
jamie-38-206
PostPosted: Sun Jul 19, 2015 10:50 am Up
Hi,
I had a recon rear axle fitted a few months ago. Keep on getting a strange metal 'ding' noise from the back near side. Has new shocks on the back also but noise still there. My mechanic says he does not know where it is coming from which I find a bit strange.
Seems to be enough clearance on exhaust.
Wheel cage is tight.
Any help will be most welcome.
206 1.4 - 2004 (TU3JP)
ukskater01
PostPosted: Sun Jul 19, 2015 2:05 pm Up
I had the same, bent the exhaust hanger bracket down and it stopped
PostPosted: Sun Jul 19, 2015 2:30 pm Up
It's normally the anti roll bar.
spike_202
PostPosted: Sun Jul 19, 2015 3:40 pm Up
I had a custom sized arb fitted but it used to make a clanging noise while going over speed bumps so I stuck the 180 back in. get 2 people with 2 hammers and bang on the arb end plates simultaneously from both sides.
**spike's project**
TEAM:+200bhp
PostPosted: Sun Jul 19, 2015 4:05 pm Up
Whenever I move my 206 it twangs. I'm going to do a scientific test by lifting the rear end and removing the torsion bars and dampers and seeing if it twangs when moved by hand.
jamie-38-206
PostPosted: Thu Jul 23, 2015 10:23 am Up
Took it into a tyre, exhaust, brake, suspension place today. It's quite a well known company. They said the back axle looks fine. Not sure how well they looked at it.
Would a new torsion bar have come with my recon axle? Is a new torsion bar a big job..... clutching at straws now Smile
PostPosted: Thu Jul 23, 2015 10:58 am Up
Is the noise coming at a particular time like cornering, braking, bumps in the road etc or just completely random?
jamie-38-206
PostPosted: Thu Jul 23, 2015 11:05 am Up
Its kind of bumps but not very consistant and not all the time. The mechanic I use said he can hear it but does not know where its coming from. I while after I got the recon axle we discovered a bolt was missing on that back rear side and it was replaced and it stopped for a while. Bolt is still there. Will try to upload a photo of the bolt.
jamie-38-206
PostPosted: Thu Jul 23, 2015 11:08 am Up
sorry image is below Smile
jamie-38-206
PostPosted: Thu Jul 23, 2015 11:10 am Up
5/4 was the bolt that was missing a short while after the axle was replaced. I knew something was wrong because of a new rear noise. My mechanic put a new bolt in. This is the same side as the noise.
jamie-38-206
PostPosted: Thu Jul 23, 2015 11:14 am Up
PostPosted: Thu Jul 23, 2015 2:17 pm Up
Had this on mine once, the bolt kept coming lose, but that was before I had a new recon axle. Where was yours from?
jamie-38-206
PostPosted: Thu Jul 23, 2015 4:23 pm Up
I don't really want to name company at moment as there is a 2 year warranty and would like to give them the benefit of sorting the problem via axle exchange if it is the axle again.
PostPosted: Thu Jul 23, 2015 4:33 pm Up
We know who that is then. Another member on here recently had a problem with an axle sent to them, if it's the same company. Look for a member called project.
PostPosted: Thu Jul 23, 2015 4:34 pm Up
www.206info.co.uk/Foru...63564.html
