Latest: williamekstrom
Overall: 17124
Online Now [101]:
Visitors: 100
Today: 37344
Total: 99329161
Forums › The Car › 206 Problems › Fuse box layout 1999 break light
Wesley123
PostPosted: Sun Jul 26, 2015 10:26 am Up
Hi guys, first time posting so I'm sorry if it's in the wrong place, my left and right brake lights arnt working and I've no idea which fuse it could be... Or is it a fuse with them both cutting out at the same time??? I've looked several times online but carnt seem to work out which fuse it is cause there are so many different lay outs on line... Any help would be greatly appreciate, maybe I can post a photo of my fuse box if it would help! Thanks
Wesley
PostPosted: Sun Jul 26, 2015 4:19 pm Up
Is your 3rd brake light working?
If not, it is likely to be the switch behind the glovebox. It is easily kicked and dislodged by clumsy passengers.
Sim
PostPosted: Mon Jul 27, 2015 3:00 am Up
Shouldn't that cause the lights to be permanently on?
EV
Jag S(crapped)- & X-Type
GTC VXR (sold)
PostPosted: Mon Jul 27, 2015 3:20 am Up
If it's popped out, yes. If it's been kicked and the plunger isn't moving out enough or the switch has packed in over time no.
Pretty sure as a safety feature Peugeot built the brake light circuit using 2 fuses (F11 N/S and hi-level. F12 O/S). Unlikely that both would blow at the same time.
