Latest: DanDan17
Overall: 17128
Online Now [249]:
Visitors: 248
Today: 25409
Total: 100625814
Forums › The Car › 206 Problems › Fuel System fault?
Fuel System fault?
OP123_321
PostPosted: Wed Aug 05, 2015 11:24 am Up
Hi,
Bit of a weird problem here.
A couple of months ago, my engine management light came on while I was doing a long journey (52 plate GTi, 138 version). The multifunction display keeps telling me I have an antipollution fault too. It didn't seem to affect engine performance or fuel economy, so I forgot about it for a while. Anyway, I finally got around to borrowing an OBDII reader the other day. I hooked it up, and it didn't return any fault codes (?!). I tried deleting codes as well, but obviously this didn't work, and the engine light is still on.
I had a look at the live data, and I think I've found an indication of what might be wrong - 'fuelsys1 OL_FAULT'. That's all well and good, but without any codes, I have no idea where to start! Has anyone had a similar issue, or can suggest what it might be? Apparently, while the reader was designed for Peugeots/Citroens etc., it was a fairly cheap one, could that just be causing it to not read the codes that are actually there?
Thanks!
PostPosted: Thu Aug 06, 2015 2:38 pm Up
Needs to be read with Peugoet Planet to get rhe fault code. Cheap ones generally don't work.
