Online Now [1198]:
Visitors: 1197
Today: 181207
Total: 155271274
Forums › The Car › 206 Problems › Engine cuts out when slowing down
Jammzo
PostPosted: Thu Aug 13, 2015 6:29 pm Up
Recently had head gasket, cambelt, water pump replaced on car, since this and after the throttle body had been cleaned the car cuts out when approaching junctions mainly or coming to a halt. This only happens once/twice a day max and usually when the car has been idle for awhile.
When slowing the engine will cut out but all electrics apart from the fan will stay on and the dash lights appearing will be battery light and handbrake. no engine light. Its not dangerous as luckily it cuts out when coming to a halt but also very annoying.
The steering goes very heavy while this happens and a usuall turn of key and im off again. any help? thanks.
PostPosted: Fri Aug 14, 2015 2:04 am Up
Will it keep running if you hit the throttle? Sounds like the idle control valve to me.
Shadowstalke
PostPosted: Fri Aug 14, 2015 5:51 am Up
Do you have an EGR valve? My car did this when the EGR was dirty and would occasionally stick open.
1.6HDi. Pull like a train. Smokes like one too!
No Smoke, No Poke!
Jammzo
PostPosted: Fri Aug 14, 2015 6:59 am Up
When it cuts and I hit the throttle then nothing happens at all
not sure onEGR, i have a 1.4 206 look.
cheers for replys Smile
Jammzo
PostPosted: Fri Aug 14, 2015 7:00 am Up
When driving im pretty sure its only when breaking/clutch is in. never when accelerating
VorTechS
PostPosted: Wed Aug 19, 2015 7:42 am Up
Staff - Vortechs
^^ Fairly sure it will be this, bit of a clean out and you should find yourself back up and running again.
