Online Now [223]:
Visitors: 221
Members: 1
Today: 40138
Total: 155758716
Forums › The Car › 206 Talk › Another question...rear shocks...sorry!
Forum Index › 206 Talk
MrMac
PostPosted: Thu Aug 20, 2015 3:52 pm Up
Sorry if it has been asked before but how hard is it to change the rear shocks on your bog standard 206? (1.4 2000) I am keeping the car for as long as poss and the ones on there are the original ones. Garage wants £265.
Cheers Very Happy
206gt160
PostPosted: Thu Aug 20, 2015 4:51 pm Up
The job is really easy and it is not really worth taking it to the garage if you are confident
1999 206 Gt... Gti180 inlet, Gti180 exhaust manifold, Gti180 injectors, Gti-6 throttle body, Custom Adapter pipe to mate the throttle body to intake, Gti180 alternator, Gti-6 ICV, Straight through stainless exhaust system, cat cams (apparently), Avo coilovers, short shift gear stick, stripped out with fixed back bucket seat and harness, flocked dash, momo steering wheel and D2 solid boss, real carbon cold air intake, Gti-6 front calipers and 288mm disks, rear drilled and grooved disks, morette headlights, sp bonnet grill 71,456 miles
2008 Audi A3 2.0 Tdi 170
PostPosted: Thu Aug 20, 2015 4:57 pm Up
Two pairs of nuts and bolts....possibly the easiest job on the car. Unless they are seized!
206gt160
PostPosted: Thu Aug 20, 2015 5:04 pm Up
If they are seized heating them up usually works
Project2062014
PostPosted: Fri Aug 21, 2015 2:17 pm Up
Get a wire brush clean the bsck of the threads & apply a small amount of wd40 on the threads then Undo.
PostPosted: Fri Aug 21, 2015 2:29 pm Up
Buy new nuts & bolts before you start the job & just use a grinder OR hot blue spanner.
Project2062014
PostPosted: Fri Aug 21, 2015 2:43 pm Up
How do you hold a blue hot spanner?
