Online Now [547]:
Visitors: 546
Today: 100849
Total: 155195366
Forums › The Car › 206 Problems › Drivers door won't shut or lock
Deano
PostPosted: Sun Aug 23, 2015 2:47 pm Up
Hi everyone I have a 206 140 02 reg today I just got out of my car went to shut the door and it just opened again it had been fine half hour before so when I go to shut my door it's not shutting if I hold it shut its not locking anyone have any ideas be much appreciated for any help thanks as I can't drive it with the door tied shut lol
Deano
PostPosted: Sun Aug 30, 2015 4:18 pm Up
This site rubbish now a couple of years ago this question would of been answered in mins
Vexs
PostPosted: Sun Aug 30, 2015 6:27 pm Up
Only if in those couple of years they had something like a search feature on the site... Oh wait DOH!!!
My GTI 180
My Old 1.4 8v
PostPosted: Mon Aug 31, 2015 4:00 am Up
A lot of the older members have moved on & a lot of other members do have a life away from this forum.
Take it to a Peugeot main dealer, they will know how to fix it.
sean.r.steward
PostPosted: Tue Sep 01, 2015 3:17 pm Up
i thought you was a admin mr bsi?
sean.r.steward
PostPosted: Tue Sep 01, 2015 3:25 pm Up
are all the latch bolts tight?
is the latch pin tight?
can you move the hook over on the door latch and return it with pulling the haddle up?
darthvalkyr
PostPosted: Thu Sep 03, 2015 5:32 pm Up
Have you tried lubricating the lock with WD40 or other spray? Sometimes the mechanisms on locks can get sticky and prevent them working properly. Another possibility could be the striker that is fitted to the main body of the car. If this has worked it's way loose, it might have moved back a little and no longer engaging with the door latch as it should. Think there are a couple of Torx screws that can be tightened up once you are happy it is in the right place. May be a case of trial and error until you are happy with how it shuts.
